Another issue that is often overlooked, with woofers that large, is their dynamics. Especially with vintages speakers as these are, they have "vintage" materials. They typically do not have the rigidity of modern materials, or their light weight. To control them effectively, requires a lot of dynamic power from the amplifiers. This is one of the reasons speaker manufacturers have moved to smaller woofers as they produce, by their very design, tighter, cleaner bass.18" woofers? Are the off the floor and also not in a corner? If you defeat midrange and treble I'd think you get less of a stereo effect. I picture a muddy sound from your speakers without much emphasis on midrange or upper end. Time for new speakers perhaps?
Another issue that is often overlooked, with woofers that large, is their dynamics. Especially with vintages speakers as these are, they have "vintage" materials. They typically do not have the rigidity of modern materials, or their light weight. To control them effectively, requires a lot of dynamic power from the amplifiers. This is one of the reasons speaker manufacturers have moved to smaller woofers as they produce, by their very design, tighter, cleaner bass.![]()
I have just replaced these woofers with new ones and they sound a lot better than my old ones. But, my listening space is quite small, so both my speakers are in corners. They are about 1.5 feet from the side walls and about 2 feet from the back wall. The center of my speakers are about 8' apart and I sit about 8' back from them. So, my triangle is 8'. These speakers are 20" deep, 28" wide and 4' tall. The good thing is I don't have a wall behind my sitting area for about 40'. These woofers will blow me out of the room so hearing them is definitely not a problem.18" woofers? Are the off the floor and also not in a corner? If you defeat midrange and treble I'd think you get less of a stereo effect. I picture a muddy sound from your speakers without much emphasis on midrange or upper end. Time for new speakers perhaps?
What brand and model are the speakers?I have just replaced these woofers with new ones and they sound a lot better than my old ones. But, my listening space is quite small, so both my speakers are in corners. They are about 1.5 feet from the side walls and about 2 feet from the back wall. The center of my speakers are about 8' apart and I sit about 8' back from them. So, my triangle is 8'. These speakers are 20" deep, 28" wide and 4' tall. The good thing is I don't have a wall behind my sitting area for about 40'. These woofers will blow me out of the room so hearing them is definitely not a problem.
Frazier Grand Marshals. They have 12" mid-range speakers and horn tweeters. When I bought them I was told they were pulled from a Disco joint.
Maybe something’s up in the tweeters , midrange or crossovers that where you usually hear the separation no in the woofers !My vintage 3 way speakers have 18" woofers. I have tried listening to different types of music and honestly if I set my speakers to mono or stereo, I really can't tell the difference. Does it make a difference that they are so low to the ground or is it me? Maybe, if I had a nice pair of tower speakers with more than one woofer and they were up a little higher? It doesn't bother me, I was just wondering if anyone has noticed this with their speakers.
That’s not entirely accurate.Another issue that is often overlooked, with woofers that large, is their dynamics. Especially with vintages speakers as these are, they have "vintage" materials. They typically do not have the rigidity of modern materials, or their light weight. To control them effectively, requires a lot of dynamic power from the amplifiers. This is one of the reasons speaker manufacturers have moved to smaller woofers as they produce, by their very design, tighter, cleaner bass.![]()
