Hi,
I am asking a question about matching a pair of Kenwood L-05M mono blocks to a Pioneer SPEC-1 preamp.
I have been lucky to find a pair of L-05Ms and a SPEC-1 that are not modified or damaged, still in good to excellent shape. My hope is to use them together
I read a post (here in AK, I think) that stated the L-0xM line needed a preamp that connected to a 10-ohm input (at the L-05M) load. One needed a matching network to ensure proper operation. As I'm not a design engineer this confused me as to this need. I don't want to assume this combination will connect directly without issue, that will end up damaging either unit.
The SPEC-1 has an output (Level/Impedance) of 2V/600 ohm.
The L-05M has stated Input Sensitivity/Impedance of 1v/50k ohms.
To my thinking this is an okay match.
Please explain if this is a good match and the need for a matching network if it is needed.
Thanks
Thanks
