burnsyaz
Hello I was recently pushing my set of a/d/s/ L9e 4 Ohm speakers with my Dynaco St-70 amp. After listening for a while I wanted to compare my 8 Ohm New Large Advents to the a/d/s/. When I switched speakers I forgot to switch the speaker wire from the 4 Ohm tap to the 8 Ohm on the Dynaco. The Advents seem to be a bit fuller sounding this way especially at lower levels. Is it safe to run them like this? :scratch2:
I have also run stacked Advents wired in parallel from the 4 Ohm tap and the Dynaco seemed to have no trouble pushing all 4 speakers at 4 Ohms.
