According to the literature, yes.
I'd be curious if anyone ever measured (via capture) the resonance of their cartridge/Black Widow arm, to see if the resonance is as high as would perhaps be predicted.
The cartridge weight is part of the calculation and important so one can determine if it can be used on some tonearms without mods. Some do come with additional weights to broaden the range of cartridges that will work with the arm.The cartridge weight does not mean anything.
What are some of that concerns about the deck and cartridge set up?The other major variable that might get lost amongst the math (and the math is settled for the most part and important) is the type of deck it's mounted to, along with how the cartridge is set up, along with a few other things specific to the exact cartridge being used.
Suspended or not, how well was the armboard fitted and attached, what was the stylus profile, etc. My point is that there may be some cases where the math didn't fully account for some combinations that might have been pretty good albeit not on paper.What are some of that concerns about the deck and cartridge set up?
Correct.What I meant was that the cartridge weight alone (without knowing or taking compliance into account) is not useful,as there are cartridges with same weight and very different compliances. That is why I said about Total effective mass , ( tonearm, cartridge, screws, nuts.......) , and compliance.The cartridge weight is part of the calculation and important so one can determine if it can be used on some tonearms without mods. Some do come with additional weights to broaden the range of cartridges that will work with the arm.
The photos didn't show me the roller guide systems in sufficient detail, so I am going by memory of seeing such in previous promotional materials. Iirc, the Souther fused quartz rail based arms were the lower cost models, the slotted tube models the higher priced end.When you follow the link (and scroll down), you find that the first three are rail based like my TQ-1. Only the TT-5 looks different in operation.
I'm pretty sure the TT5 is a two point bearing tube tracking guide type. I cannot find a decent pic from the rear showing how the arm hangs on the roller carriage.When you follow the link (and scroll down), you find that the first three are rail based like my TQ-1. Only the TT-5 looks different in operation.
Agreed. Upon closer examination, so is the TT-1. The TT-2 and TT-3, however, both have visible races for traveling across the rails like mine:I'm pretty sure the TT5 is a two point bearing tube tracking guide type. I cannot find a decent pic from the rear showing how the arm hangs on the roller carriage.
I see a slotted glass tube with a two roller carriage in both pix.Agreed. Upon closer examination, so is the TT-1. The TT-2 and TT-3, however, both have visible races for traveling across the rails like mine:
The drawing is indeed the Souther system, with the triple roller carriage and jeweled vertical gimbal. The Cantus slotted tube system has a twin roller carriage coupled rearward out of a slotted glass tube without the vertical gimbal.Maybe I'm confused by your term "slotted tube". I have the original documentation and the only reference to a "tube" is for the tone arm itself. The arm assembly travels across the quartz track.
Slotted tube:
What I see with the TT-2 and TT-3 is a similar quartz track that operates identically to ours. Just more massive structure to support the arm.
But can you say that in German?The drawing is indeed the Souther system, with the triple roller carriage and jeweled vertical gimbal. The Cantus slotted tube system has a twin roller carriage coupled rearward out of a slotted glass tube without the vertical gimbal.
Cantus slotted tube guide track.
Fwiw, the very low mass active tracking Linatrack system that Revox adopted doesn't use an arm as such, more a unipivot gimballed counterbalanced cartridge carrier.
I left out "magnetically stabilized",But can you say that in German?![]()
How does one ever change cartridges with the lead wires that are about as big as one human strand of hair? I'm not going to even try at this point. I have a medium speed Grado in it .I've always had a strange obsession and desire to own an Infinity Black Widow tonearm. So this many years later what does the collective brain trust of AK think of it? And specifically the later version with the graphite tube not the early aluminum tube which was prone to breakage.
