Is there a way to fix the built in amp?
RT4250
I bought a Denon DP - DJ 151 turntable at a pawn shop for Christmaslast year. It has a switch on the back labeled phono / line . My understanding is that the"line" side does not need a preamp. But there is almost no volume. Is there a way to fix the built in amp?
If you go to this link, scroll down to "Downloads" and you can download the manual for that turntable. It says there is a coaxial digital output, so you could try that to your receiver to at least get some use out of the turntable, if the analogue output isn't working for you.
http://denondj.com/products/view/dpdj151
Good luck.
Thanks for the p
Manual link. Looking it over it talks about making sure the receiver is set to MC or mm to match the cartridge? What is mm and MC?
