You are right in what you say (that the higher powered unit also offers additional advances that influence the end result), however the bottom line is that the higher powered model does sound better. Perhaps not totally because of the higher power - and headroom that offers - but it does.I believe that, with some brands, the more powerful amp has the likelihood of sounding better than it's weaker brothers simply because a higher cost may help ensure a more advanced design and higher parts quality, but not even this can be assumed. Sometimes, it seems to me, the lower price can result in a particular KISS design that just comes out better than expected - the Adcom GFA-535 leaps to mind for me; it certainly was well-received by many audio reviewers and audiophiles. I bought one and loved it.
given that all else is the same, is there any reason as to why a more powerful amp should sound better its less powerful counterpart besides the bigger one's ability to sound louder?
When reaching the speakers i mean...
One experiment I did and equalizes all other factors as much as possible was to try a single 2x70W power amplifier to drive a pair of 200W speakers (KEF 105) and then try two of the same amps in bridged mode where they deliver 180W output. At higher volumes - where the 70W were exhausted during peaks - the bridged amplifiers delivered an audibly cleaner sound. Relaxed and seemingly less loud - due the the lack of compression perhaps - than the 70W mode.
In my experiment, everything was the same - except power output. The amplifiers were the same utilising the same components.
Given that all else is the same, is there any reason as to why a more powerful amp should sound better its less powerful counterpart besides the bigger one's ability to sound louder?
When reaching the speakers I mean...
As a counter to everything I said above- my 15-18wpc Leben integrated subjectively sounds better than my 400wpc Levinson. Depends on the mood I'm in (and the efficiency of my speakers). I was giving reasons why I liked that amp, but there are plenty of examples of smaller amps that sound better than more powerful ones. As said above "it depends".
A small amp will have less control over the speaker cone than a large amp.
If a concert speaker rated at 2000W, 4 ohms, and containing 2x18" woofers were connected to a 20W amp then the sound would be flat. The 20W amp simply could not manhandle the air mass around the 2x18" cones.
Big amps sound better for a simple reason. They are better able to force the speaker cone movement to faithfully reproduce the shape of the electrical signal.
...A small amp will have less control over the speaker cone than a large amp.
Explain the mechanism by which a small amp working within it's range has less "control" over a speaker than a larger one. Explain what you mean by control.
Two points:
-Amplifier topology and power supply have more to do with driving (and stopping) a large woofer; as well as dealing with funky reactance of cabling/crossover/driver/cabinet issues. Having additional wattage at the ready IMO is for most amps, really having more power supply at the ready.
-We need to define "a small amp", because I believe you and I are really on the same side of this. My Krell is a small amp by most AKers definition, as are my Levinsons. The Krell is a mere 80wpc into 8 ohm. The Levinsons are all of 100w each. Heck, a Pioneer SX-1280 is 185wpc. That's a lot BIGGER. Or is it? Each one of my measly amps weigh around 100lbs each. The Levinsons each have a pair of 600va transformers. My amps are not small. They can control a woofer better than most (assuming they are asked to drive a given speaker to a certain SPL, based on efficiency and amplifier gain).
But I agree that big amps push and stop woofers better. I'm just trying to define Big and Small, and not necessarily match them with words like gain.
Yes?:thmbsp:
A smaller amp will not be able to move the cone fast enough to faithfully reproduce the music signal. Even when it is within its range, i.e. not clipping, it will be limited by slew rate.
