linuxslate
Well-Known Member
Background:
I have a Grundig RF-250U on the bench. I wanted a tube table radio for a while, and I wanted stereo, and a magic eye tuning tube. So when I came a cross a Grundig RF-250U locally, I went for it.
Overall the unit is complete, mostly original, and very good cosmetically, but it needs some help in several areas.
Right now, I am dealing with a failed bridge rectifier. (B250C100). It was bulged, and a blackened terminal fell out when I was de-soldering it.
I know that replacing selenium rectifiers with diodes has been covered here ad-nausium, but I'd like some opinions on this specific unit.
Questions:
Is this even a Selenium rectifier? It looks different than the part shown on radiomuseum.org https://www.radiomuseum.org/tubes/tube_b250c100~2.html
It's also no larger than a modern bridge rectifier. Is it possible that at some point they went to silicon or germanium?
Whatever it is -- is it likely that it is something that will not have significantly more voltage drop than a modern bridge rectifier?
I have some 600 PIV bridge rectifiers salvaged from modern SMPS's, and was planning on using one as a replacement.
It's a very straight forward power supply. (-) of the bridge is jumpered to the chassis, and (+) goes to the PC board to become B+. I figure if my B+ is too high, I can just put a power resistor between the bridge and the PCB. Any other suggestions?
Questions:
. I'm fighting a combination of the infamous German gang switches, and the fact that the top broke off of my can of CRC contact cleaner.
), Tone and balance work more as they should.
