is this an infinity woofer?
mr.jones
AK Subscriber
ebay seller has an 8'' poly woofer that looks idendical to the Rs 6B woofer part # 902 4976. The part number on the ebay woofer is 490818 and the seller can't recall the model of the speaker but says they are infinity. I need an RS 6B woofer and wonder if these will work.
I was trying to figure those out as well because they also look kind of like the 902-2666 from the RS 3000 and 4000 except that they have a raised edge instead of a depressed edge with a gasket, the frame shape is different and the color is brass instead of black - too much disparity for me.
Since it would appear that the RS6B woofer has the same raised edge, the only cosmetic differences would be the frame color and possibly the shape of the frame. Still if you are looking for a single matching replacement, I think I'd hold out for an actual 902-4976 which is likely to show up eventually, so as to keep your 6B's 100% original. Otherwise the Infinity spec sheet indicates the 902-5030 as a replacement woofer for the RS 6B but I think in that case you'd want to replace both woofers.
