Hi,
I am working on a SG-9800 Equalizer and have a question on a couple parts.
This unit does not have a fuse in the circuitry. The unit does have two resistors in line with the rectified power before the regulation circuity.
The initial issue was a burnt resistor (R902). This led to discovering burnt transistors in the power supply.
The resistors are R901 (5.6 ohm @1/2W) and R902 (6.8 ohm@1/2W). The description/designation of the parts is "RD 1/2 PSF xxx J". These parts are listed as critical safety parts to be replaced with exact like parts.
Are these components actually fusible resistors that are the fuses(protection) for the unit? I think so but want to verify with those that know more than I do.
Thanks.
Thanks.
