Is this pic rockwool or not? AR-2AX thanks
Vttj
New to vintage audio so appreciate any direction to other useful info. Into a set of AR-2AX due to pots. These appear to be aprox 1969-71 speakers with cloth subs. Is the backing in these speakers rockwool or fiberglass? I have attached photos.
They have been into before as capacitors updated so maybe this has been replaced but don't think so as some is rather matted. I like to keep the original intended sound so ok to keep the same backing? I understand some issues with pots corrosion and rockwool. Honestly a bit more concern if asbestos risk. Any help appreciated thanks.
I just looked it up...no need to worry about asbestos. "Rockwool" is a brand name but mineral wools in general are made from stone and slag left over from smelting in a process similar to making cotton candy.
I can't say how it may work in speakers but it looks like a better product for homes.
And I agree, it looks like fiberglass in the pics.
You can reuse the material when your done cleaning the pots.
When dealing with Rockwool/fiberglass from these cabinets it's always best to wear sleeves, gloves, and a mask, and work outdoors (or in a garage like you've done).
Another thing you can try when you have intermittent pots is to put the speaker face down and spray a bit of DeOxit D5 on the pot stems and let it seep into the pot for a few minutes. That may improve their operation enough so that you don't have to go into the cabinet.
Ordered some DeOxit D5.
Looking at the AR rebuild guide this looks like Rock Wool to me. If so seems fiberglass is way i must go. Need to figure out how much?
