Started the recap on my Scott 340-B
I have replaced all the .1, .022 and .027 caps
My question is...is the picture the selenium rectifier?
If so, is there something I can replace it with that Radio Shack sells?
Looks like one. A bridged rectifier of the appropriate voltage and current will do.
According to this French forum, this is indeed a selenium unit, rated 60 volts,
200 mA. Look at the fine pictures!
http://www.audiovintage.fr/leforum/viewtopic.php?f=82&t=2282
http://www.radioshack.com/product/i...ce=CAT&znt_medium=RSCOM&znt_content=CT2032230
More than adequate for the job.:thmbsp:
That one is web only...this one is in stock within walking distance...will it be okay?
http://www.radioshack.com/product/index.jsp?productId=2062583
Sure will..Plus(+)wire goes to the plus(+)lead,minus(-)wire to minus(-)lead and the other two wires are AC input and doesn't matter which wire goes to which lead.
New rectifier installed...thanks again avionic :thmbsp:
Damn.That was quick..
Check your B+ voltages. You may need a dropping resistor in between the + lead on the new rectifier and the first cap to drop things back down. Silcon has a much lower voltage drop than selenium does.
