Base voltage on q35 = -63.8 voltsknowing q35 base voltage would be a big help
well if top left is a diode than you can see my reading were 0.4v and 0v... faulty?Back in business. So D33 is on top left. You should have - 0.6V on anode. If you brush that PCB you find parts and traces easily.
it appears to be sort of working .. renew the solder on it as it appears cracked to me .This is q35... i thought the top middle was the base, but could be wrong? DC voltages on each
Next step?it appears to be sort of working .. renew the solder on it as it appears cracked to me .
renew the solder on it . like remove old solder from all 3 legs and add nice new solder .K....
Next step?
Pin 21, 28 is groundvoltages not making much sense but pin 28 should have one of those negative voltages instead of the positive one that is there .
