on the main amp are coils L1 and L2 . these are in parallel with 10 ohm resistors . you need to you set meter on DC volts . black probe to shiny chassis red to those resistors legs . doesn't matter which end so long as its a good connection . these should ideally measure zero volts . report back with your results .
p.s tape up the probes so just the tips are showing to reduce the risk of shorting something out .
