quiet
Addicted Member
I picked up a soon to be nice pair of working KLH 17s with the wrong tweeters. The tweeters had been replaced with Realistic 8 ohm dome units that don't cover any of the midrange as the original 17 tweeter did.
They sounded pretty bad.
Some 3.3 ohm caps or somethings had been added at the tweeters to make the speaker 8 ohms again.
I think this was done because the KLH tweeter itself is 4 ohm not 8. So when I replaced the Realistic tweeters with a pair of correct 17 tweeters I had on hand I just removed the 3.3uf whatever it is along with the Realistic tweeters. The tweeter wiring looked original otherwise.
Did I remove the woofers and check the crossover wiring for changes also? Noooo, as a rookie why would I?
When I plugged them in and fired them up they sounded much better for about 10 minutes at low volume. By then I was thinking this is great.
So I turned them up some more. They sounded great, for about 5 seconds. Then left crackle......... right crackle ....... no more mid or tweeter sound.
Turns out the crossovers had been completely by passed and the tweeters were running full range in an effort to get more out of that realistic tweeter that was never doing to get the job done.
More caps and tweets on the way. Love this hobby.
