Certainly no offense taken . . .It’s really cool that lots of you guys are techs and can fix your own gear. That’s a useful skill and one to be proud of. But if your logic about having to learn because you have to to own it carries over, you would also need to be an appliance repairman, computer tech, auto mechanic, roofer, carpenter, etc.
Most of us think we’re kinda handy with tools but most of the tradesmen I know took years of experience before they were proficient at their job.
No offense fellas
I am going to post my story on there, but while registering, I for the life of me cannot figure out the answer to this question.The solder was "too old"? Never heard that one. And all the solder back then used lead. Much of the modern solder does too. It's actually much easier to work with than the lead-free stuff.
I've restored lots of vintage tube amps that are older than any little transistor radio and I've never had any issue. That said, they've all been wired point to point and I do know that it's possible for vintage circuit boards to be damaged. But, if you're careful, it should be do-able.
I sounds to me like he just didn't want to work on it and makes me wonder just how qualified he is.
This reinforces my earlier suggestion, and the suggestions of others, that you really need to learn to work on these yourself. A unit that isn't working is the perfect candidate for you to start with. If the board gets damaged, oh well. It didn't work anyway and it's still going to look just a cool on a shelf as it did before.
If you haven't already done so, you might want to register on the Antique Radio site. They have a forum that's exclusively about early transistor radios. I'm sure there are members there who would be absolutely thrilled to help a teenager who's interested in radios. Tell the story about solder that's "too old" and they'll be
https://antiqueradios.com/forums/index.php
I bet they would gladly walk you through the repair process and there might even be someone on there who is local to you and willing to give you hands-on lessons.
I tried one of those food items and was able to register. I appreciate the hint!I would assume the food. Fried chicken and rose candy?
Speaking of ham, I have a friend in high school who is into Ham radio (at least that's what I think). I bet he knows a place or two for hamfests, so I think I'll ask him tomorrow during lunch and see if he knows of any hamfests.Hey Romeo, I know I must sound like a broken record, but if I were in your shoes, I would google hamfests in your area. There is almost certainly something not too far away and not to far in the future. Bring your radio. Ask around a bit or just find a table with old radios and an even older guy selling them. Our hamfest here is small by most standards, but it draws a lot of antique radio enthusiasts. Yeah, it will probably smell like BenGay, but you will probably find more than one person that shares your passion of old radios and has expertise. Good luck with the old solder.
There is a huge difference between a mechanic and a technician.There is a HUGE difference between a mechanic/technician and a parts changer.
I watch his videos every time he uploads, and have been for well over a year. "Nothing but the best."Check out shango066 on YouTube, if you haven't already. He does a lot of transistor radios and is respected by many over at antiqueradios.
https://www.youtube.com/user/shango066/videos
And that's exactly what I would do.If he wants to continue to collect them, paying for repairs gets expensive and his involvement in the hobby will be extremely limited by his lack of funds. I'm sure he would rather spend $50 on a new radio than an hour of some tech's labor.
Might be a bear to get at that board. Looks like tuner string needs to get moved. Doesn't looks like there are many capacitors in that board either. Might just be an issue with those cap values drifting down over all these years. Unless you know how to do the work its probably not worth fixing tho. Hope you can find someone to do it gratis.I realized I haven't posted pictures of the GE here (like I usually do), so here's what we're working with for the time being.
Loose battery door latch
Solder tracesView attachment 2478321
The PCB can actually slide out so you don't have to remove the string assembly. Besides, if you have to remove the dial string, it shouldn't be that complex to re-string unlike a lot of other cheaper transistor sets. You can also lift the antenna bracket up and away to get at the solder joints.Might be a bear to get at that board. Looks like tuner string needs to get moved. Doesn't looks like there are many capacitors in that board either. Might just be an issue with those cap values drifting down over all these years. Unless you know how to do the work its probably not worth fixing tho. Hope you can find someone to do it gratis.
No offense fellas
Key operative words.when working properly
But nowhere close to a decent hifi rig. They are collected more as a novelty these days.will wipe the floor with many other transistor radios in terms of bass response and power output
No offense fellas
... having to learn because you have to to own it carries over, you would also need to be an appliance repairman, computer tech, auto mechanic, roofer, carpenter, etc.
