"I've made a terrible mistake" - Gob
StoryMe
Hangs his head and sighs.... I messed up.
I needed to clean the knobs on a Marantz 2270 that I'd picked up and was refurbing a bit before putting into use. New bulbs, new velum, new power switch, cleaned pots. I was learning a bit as I went and had watched a youtube video suggesting that I soak the knobs in some 409 cleaner to clean them up. So I dumped some in a glass jar and threw the knobs in. Then forgot about them. Then left town for 4 days.
When I took the knobs out, to my absolute horror, each looked like they'd been burned with a lighter. The structure of the knobs are the same. Same texture. No physical damage. But the visual is catastrophic. They are each their own very special brand of ruined: matted patchy black and splotchy chalky white.
I don't know what to do. And of course these knobs are like $30 a piece on ebay. So I've essentially done something like $150 in damage in one fell swoop. The word crestfallen comes to mind.
I'm wondering three things:
Is re-plating possible?
Is paint an option?
Any leads on a reasonably priced set of replacement knobs?
If anyone has any experience with similar or suggestions, or even if you just want to give me a hard time, I'm all ears. I certainly deserve it. I'm at a loss.
Lesson learned: Don't soak your knobs in 409 for too long
409 they still make that stuff?! Must have been the ammonium that did that. Soap and water works well.
I would try a good paste type metal polish like Flitz, Simichrome etc. It looks like the ammonia just discolored the metal. I would think you could bring those back with careful hand polishing...
Just the type of advice I came here for. I'll give this a shot and report back. Thanks Sandstrom
Well, I would really like to bust your chops, but I feel generous today. :rflmao:
Instead, Welcome to AK! :beerchug:
Welcome to AK!
If you have access to a dremel type hand tool. They have a small brass wire brush and cloth attachments that may clean them up.
Doubt it hand applied car or plastic polish will cut thru that buildup.
