Well not sure how to judge the performance. I can almost see the broadcast antennas from the station I listen to the most.
BUT the few times I have tried DXing I have been very impressed at the number of low power stations I have been able to pull in.
we have a 135watt college station KWBX 90.3 FM in Salem it is only 12.2 miles away but it is on the far side of a hill much higher then the antenna which is just a short tower on top of one of the buildings.
The Radio Locator site puts me on the very edge of fringe reception for this station and I can pull it in pretty good in Mono (not even sure they do Stereo it is a religous program)
I can also pull in a 10 watt station in Dallas, Oregon that has it's transmitter in Falls City about 35-40 miles away but almost in a straight line following a slot in the hills along the Willamette river. I see that that station is no longer listed on the Radio locator web site. So I don't have details.
I'm very happy with the way the stations I listen to come in if the stations signal is clean so is my reception. Compared to a 300 ohm wire Di Pole antenna the J Pole is outstanding.
I also have a Modified Qubic Quad (double square wire loop) antenn on the ceiling in my office and the J Pole and it are pretty close in pulling power.
My plans in the future are to go to a manually adjustable YAGI antenna. I have the ability to run a antenna mast through the roof into the Alcove under the stairs my system is in so that all I would need to do is manually turn the shaft to point the antenna. But that project is a ways off. Most likely I'll do it when I put on a new roof in a year or two.
And for those thinking about that. We are in a VERY low risk of lightning area and I will use a non conductive material for the mast.
