guitargrump
Hi everyone I am building a FM j-pole antenna to boost the FM radio stations I can receive here in the mountains...
I've heard and read good things about this design and decided that I would make one and see if it was as good as it's reputation...
It seems very simple from the diagrams I've read...
This one plan made sense to me and agrees with several other j-pole plans I've read dimensions wise and that's why I picked it...
I'm about two thirds done with the antenna now... I still have to find the coaxial cable that I intend to use. it's in my materials hoard under something somewhere around here...
The plan I chose to mostly follow was posted here http://uncleikejpole.blogspot.com/2012/?m=1
So far I've used
One 10' long 1/2" piece of copper tubing
2 end caps
1 tee
1 90°
A couple of scrap pieces of PVC and a couple zip ties... And a piece of scrap brass for the cable eyelets...
A picture is worth a thousand words so here's a bunch of pictures...
I'll post more pictures as I finish up the rest of the antenna installation... It might take a couple of days but I'll try to show everything that I do... And I'll report my results...
From what I understand this antenna design can be used for a small FM transmitter antenna too...
but you need a FCC license for more than a couple of transmission watts so...
I think the FCC power limit is 7watts for home and church use but I'm not sure so...
The plan doesn't actually show a earth / ground connection to the bottom of the antenna mast but it definitely needs to be well grounded...
So far I've used
2 end caps
1 tee
1 90°
