hardcore 81
I'm a newbie on here so be kind. After looking at some of the posts on here over the months it seems that many people on here dont rate the jamo D265/266 very highly? well, ive had a pair of these speakers for over 15 years and over those years have spent an aweful long time and a lot of effort to turn them into truly STUNNING speakers. first out went the crappy foam, then the cabinets were reinforced, then the speaker baskets were damped with dynamat, then the base of the drive unit magnets were treated to an epoxy filler, then dynamat was fitted to the insides of the cabinets, then a humble egg tray was used behind the 12inch bass driver glued to the back panel and the void behind this was packed with sheeps wool, then 2inch thick celotex panels half the height and width of each panel was glued to the center of each of the top,sides,back,bottom. then sheeps wool was used to fill voids inside them. the speakers stand on oak stands and feet made from a yew tree. see my avatar. also the plastic rings around the bass driver dont hold it in to well so the bass unit is further held onto place by six screws holding the speaker basket directly to the cabinet. also the plastic black plates on the tweeter grill either side, the void behind this is filled with epoxy filler.
