Jeromatic
Hey Everybody!
Long time reader, first time poster here.
Recently I had the good fortune of winning some Janszen Z-300’s at an auction. One of them works well....sounds FANTASTIC... The other has no life coming from the electrostats.
I’ve replaced the power caps, a pot, the rectifier (with three diodes in series). The transformer on the ac line tests OK… but the transformer connected to the stats (labeled “Model 65 8 Ohms”) has an open secondary.
David Janszen of Janszen speakers (who has been very helpful) suggested that the flux joints inside the transformer on the secondary might be corroded where the connection wires meet the fine winding, and may need to be resoldered. After digging through lots of insulation, I found the connection wires disappeared underneath the “belly band” that is wrapped around the top of the transformer, so I never reached the fine winding, then I gave up. Here's some some after pictures:
Does anyone have any ideas where I might find that fine winding connection, and how I might get to it? I think I would also seriously consider replacing this transformer if I could find a donor, or a similar transformer that could do the job of powering the electrostats. Any help you guys could give would be greatly appreciated!
