I just picked up a HK 670 in reasonable shape. The tuner section has a small gear on the end of the strung pulley that drives a larger gear on the tuning capacitor.
In the process of pick up and handling, the pulley backed out of position, allowing the small drive gear to fall off. It seems to be oriented by a double D cutout and the flattened shaft of the pulley.
It was a bugger to get back into place without taking down the entire dial string, something I'd like to avoid. When I did get the gear back in place, I did not index the gear teeth perfectly, as the dial indication is off from the actual station frequency. There seem to be two ways to re-align the dial, rotating the pulley on it's shaft or moving the pointer on the string.
So, back to the original title, the pulley is secured by two screws clamping it to the shaft. They are locked in place with a familiar green compound that I've seen on other vintage units. I tried chipping free as much as I could, but I was unable to budge the screws. They are small, and I did not want to destroy the slotted heads.
Anyone have a trick for releasing this stuff? Heat and solvents come to mind, but I can't really apply heat to the pulley bushing, as the pulley itself is plastic, and 40 years old. Moving the pointer looks challenging as well, bits of glue secure the pointer to the dial string.
Any suggestions would be appreciated.
