brhalltx
I'm pondering, especially after a $400 quote to refoam two 128Hs and two PR300s.
Heat and humidity and garage aside (it's hell living in the heat and humidity capitol of Texas; can't glue inside, due to she-who-thinks-she-must-be-obeyed and asthma and allergies), it doesn't look too hard, other than making sure everything is aligned.
Is it better to use the test tone or shims? Or both?
And, does the 128H have foam under the dust cover that should be removed/replaced?
