Maybe something like a ginormous Jubal sort of 3-way would work with these. Using the 2240/2241 18"ers, LE-8s and 2405/ 077s. Crossover points at 200hz and 8K. LE-8 looks useable up to 10K. And they are quite nice sounding. With the low cost of these 18"ers these could be real sleepers. Don't think they'll kick the 4333As to the curb any time soon though but I'm intrigued by the "lighter and tighter" claims of upper bass definition. I didn't even think about building a set of loudspeakers with the 2241H, I was only thinking subs at the time.
If you don't biamp, the LE8 may not have the effeciency to keep up with the 2241. You can add a parallel 20 ohm resistor to the 2241 to drop the impedience to ~5.7 ohms and reduce the volume by ~1-1.5 dB. I currently do this with the Ethel Mermans with the 2251Js (~9-3/4"), which I would think would be more effecient than the LE8s. Although you could use a series resistor to get more reduction, you wouldn't want to because you would loose dampening. You would want to consider this in your crossover design. The reduction in impedience raises the crossover frequency, and I've added an additional 100 mfd to the 62.3 mfd on the 2241 when using the 20 ohm resistor. I put these resistors and caps on dual banana plugs and I can simply plug them in to the woofer output terminal on the external passive crossovers essentially piggyback with the 2241s. The 100 mfd Audyn caps are too big to fit in the crossover cases.
Also, some of the other JBL offerings of similar/slightly larger size have 3" or even 4" voice coils rather than 2" voice coils used in the LE8s.
Also, something else to consider. As of late, I've been running the Ethel Mermans as 2.5-ways. I've by-passed the high pass filter to the 2251Js letting it roll of naturally at the low end.
I did lots of experimentation, and using the 32.3 mfd high pass cap on the 2251, the difference was only an increase of about 1 dB at 40 Hz without using the cap. IOW, based on the natural impedience curve and roll off of the 2251J, the cap ain't doing squat to protect the driver at the low end.
It is however, throwing off/reducing the lower end of the 2251's natural curve yielding reduced volume in the lower midrange (~200-400 Hz) where it would be nice and flat to better meet the 2241.
There is a lot that goes into getting a crossover right.
