asilker
Ok, I will gently proceed with block and hammer. And if that doesn't work, I'l give it a big ole smash and bust everything loose
Just kiddin'.
I was able to get the mids out earlier today, one is working great, the other one has a lot of rub and while it's making noise, it's quite a bit quieter than it's counterpart. I was able to snag a pretty clean pair of LE5-6 mids on ebay for a great price so I went ahead and pulled the trigger. According to the LE5 matrix over at the Lansing forum, the 5-6 and 5-10 are essentially identical. I'll probably see if I can get rid of my 5-10's. I think if I wait a little while and keep them up on the bay, I might actually be able to make money on this swap.
Until I can figure out what the problem is with the one tweeter, my plan is to source a replacement at a price low enough that I can get rid of it quick if my current one turns out to be ok. Just covering my bases.
So after today I think I'll just need to buy new Lpads as mine sound like sand. They look quite a bit more expensive than potentiometers, I was not aware of that. I'm going to search around and see if there is a thread on just using resistor values to hard wire to the "5" position on the dial. I like the idea of just setting and leaving it.
Just kiddin'.
