Danbo69
I have recently acquired a pair of 4311Bs from a local thrift shop. Overall they are in pretty decent shape, but I am planning on refurbishing them to make them look new again. I'm pretty comfortable with redoing the cabinets as I have pretty decent woodworking experience and done several cabinets that have turned out very nice. I do however have a couple of other questions that perhaps some of you who are more familiar with these can answer:
There is a goop that has leaked down from the woofer and has run down the face of the speaker. It seems like a sealant from the woofer surrounds and in practically every picture of one of these I have seen it, so I know it's a common issue. First question, what works to clean that off without removing the paint on the speakers? Second, do I need to put some sort of sealant on the surrounds to keep them from drying out?
Speaking of the woofers, it seems most of the pictures show the black leads on the white cones canted to the left, but on mine they are canted to the right. It seems like mine have been that way for a very long time as the goop from the woofer surrounds has run down as they sit. I know it would simply be a matter of turning the woofers 90 degrees, but am curious if there is a "correct" way that these came from the factory, or if mine have been manipulated at some point?
Finally, how important/difficult is it to replace the capacitors on the crossovers? These have large, cardboard capacitors, and I haven't pulled mine out to look at them yet, but is this a must do, or a should do?
Thanks
Thanks
