If you were to switch the tweeter and midrange, you would have to switch the small chamber behind the midrange too to get the proper loading for the midrange, and the appropriate isolation from the woofer for the midrange (the tweeter is closed back so no problems there). You would also have to notch the opening for the tweeter connections as they are on the original hole. Screws are the same for both drivers. You'll need to work from the woofer hole to get at the backside and routing the wiring. Check the schematic in the diagram for wiring details.
See this exploded diagram for details of the chamber (port and plug) - what is not there is how it is attached to the baffle - Likely hot glued. You will be running the wiring, I think, through the plug or tube. Note there were two different cabinets depending on L or R. But not uncommon for people to have received two lefts or two rights. Its just one of those things.
Take pics of your current set up for reference. Obviously, you only need to do this on one speaker.
Some people feel the imaging is fine either way, others feel there may be a bit of difference. Only way to know is find a very good recording that you know provides a lot of spatial detail and play it on a set of speakers that does that well. Then sub in the 4312's and see how they are currently. You'll have to play with height, toe-in, if any, and placement for optimum results.
Good luck!
