travellersol
thanks. there are certainly many things to learn in this hobby......Tubbiness and the many other terms are subjective at best and everyone will tend to use them slightly differently.
If you've ever met any stereo or audio reviewers (I have), they're basically writers who like music, get equipment to demo, and some of them have just better than marginal spaces to set up. If it can't be made to sound good in your listening space, it's not for you.
I have found that the older monitors are great at making music, but each generation continues to get slightly better in imaging and other important musical elements. What some call soundstage, I call "concert hall effect" where there's more cross-channel echo giving lots of airy openness, but no real defined and accurate imaging of a properly miked recording. Or in other words, if the clarinets are recorded at 11:30, they should always be at 11:30, not moving around the stage. Many recordings are (as mentioned above) mixed with the music purposely delayed into the 2nd channel to give the concert hall effect, it's impossible to correct this with good speakers and placement.
Much development in JBL Pro speakers went to help evolve imaging of a pair of speakers in a less than perfect environment. The Engineers understood the relationship between first-arrival sound and second-arrival sound and how the brain processes it, worked hard on designing speakers that can create proper imaging even with expected reflected sound in this imperfect environment that the monitors will see. The imaging of these later monitors is excellent, try out a pair of 4410As or LSR6328P/LSR6312SP and you should be very impressed. I haven't been so lucky as to listen to a pair of M2s yet, ... on my list. The point being that imaging is very much a primary goal of modern studio monitors.
Another point is is how critical the environment is and how pros set up a venue. If you take the time to measure the room for standing waves, decay, and other things that affect not only imaging but cancellation and other reflected-sound effects, you have a very good start in designing a speaker installation. Without this critical data, you're pretty much shooting in the dark.
. Did you mess with the crossovers? It’s possible that the problem could be the speaker AND the distance. The OP is definitely too far from the JBL 4341s!
