Has anyone here ever recapped the crossovers for JBL 4401 Control Monitors. They have parallel caps in the crossover and as per an old review by Ben Duncan: "polypropylene capacitors are wired in parallel with the reversible electrolytics to improve the top-end response, or, in JBL's parlance, "reduce the hysterisis effects... this provides improved resolution of complex transient waveforms". He also goes on to say "the polypropylene bypass, at 68 nF, is way too high to have much audible consequence, so the effect is presumably purely psychological."
Any recommendations on how to recap? Use the same parallel setup our just replace with one capacitor in each location? I believe the little yellow caps are the 68 nF (or 0.068 uF) polypropylene caps. Another basic question: Do these caps even need to be replaced?
Also - is the 14 uF cap for the L-pad? Am I correct to replace it too?
Thanks
Thanks
