The tweeters are called Buttcheeks.
Yeah, but Heather's moniker of "Dolly Parton's" is starting to grow on me.
I'll take my 4430’s with a pair of Pamela Anderson's thank you very much.
Nice find.
IMO, great find and nice of your company to let you have them. Anything else in storage???
I wonder if the QSC amp was configured with a crossover frequency dialed in so that the vocals and top end were rolled off, i.e. A sub woofer amp? Also, most pro amps need more voltage drive to reach full power so a consumer device like an iPod unless plugged in might not be stout enough to drive this amp well. Consumer amps typically need less voltage to reach full power.
As for the woofers, whether you or the tech do the refoams, get well fitted foams (Rick Cobb highly recommended), and be sure they are affixed / glued to the back edge of the cone only, not the front. Rick includes a test tone CD or use your signal gen app to play test tones at low volume to check centering and freedom from distortion. That way you don't have to cut or replace the dome for shimming method. Be sure to carefully remove and save the front outer neoprene gaskets and reglue them when you have finished the refoam. This will preserve the OEM appearance. While you have the woofers out, you can touch up the bright front metal frame edges with a med-coarse file but round off the edges so you don't get metal burrs or splinters. This will look nice when the grilles are off.
Since the speakers' mids and high end came back with the new amp, you probably don't need to replace the compression driver diaphragms just yet. If you have time and inclination, you could open the cabinets up to check the type or model number of the compression driver, one used an aluminum dome, the rest used titanium. If there is no apparent distortion with properly filtered signal, I'd suggest playing them for some time with familiar music and see how you like them. They do top out at 15-16khz though so don't expect whopping top end.
As for any replacement diaphragm, use only OEM certified JBL (expensive) or Radian brand (a little less expensive). All the rest that are cheap are just that, cheap Far East copies which do not perform anywhere near JBL spec or quality. If you want JBL performance, you must use JBL parts.
The only other weak point is the internal / external crossover switch which usually needs a very good DeOxit cleaning and preservative, or removed entirely.
Any problem with playing music at under 4watts with the foams attached but basically trash?
I finally got both speakers together and got a Yamaha WXA-50 to power them. Now I think its time to start going through Zonker92's mods and seeing if I can get some more bass out of these. Bass is pretty nonexistent right now and it would be nice to have a little more bump in them. I will get a picture up soon after I redo the grill fabric.
Even with the lack of bass, I have to say these are some easy listening speakers. I pretty much turn them on when I get home and have something going through them until I go to bed.
Thanks for the info EarlK. You are probably right about the foam breaking down. I'm not sure I would describe it as distortion. There is no scraping sound it sounds more like the foam surround slapping the basket. Either way it may be worth having them rebuilt by a JBL pro.
Keep in mind these speakers are REAL STUDIO MONITORS,there not supposed to color, only reproduce what is actually there.The lack of low frequency could be your placement, possible phase problem ie wired wrong, also these speakers were intended to be installed in a sofit which if done proper is an expensive enchilada .THE SOLUTION buy a Veledyne powered sub NOT A CHEAP ONE, then hold on. I have this exact system in my house You won't be sorry.I finally got both speakers together and got a Yamaha WXA-50 to power them. Now I think its time to start going through Zonker92's mods and seeing if I can get some more bass out of these. Bass is pretty nonexistent right now and it would be nice to have a little more bump in them. I will get a picture up soon after I redo the grill fabric.
Whoops its Velodyne powered sub. They have several on ebay.Keep in mind these speakers are REAL STUDIO MONITORS,there not supposed to color, only reproduce what is actually there.The lack of low frequency could be your placement, possible phase problem ie wired wrong, also these speakers were intended to be installed in a sofit which if done proper is an expensive enchilada .THE SOLUTION buy a Veledyne powered sub NOT A CHEAP ONE, then hold on. I have this exact system in my house You won't be sorry.
