FireGuruMN
A pair of 4435's showed up on the local craigslist for a reasonable price and I landed them. Got them out of one basement and into mine with no injuries to the speakers or the movers. They are 250 pounds each if you are wondering why I mention that. After factoring in a Florida vacation so my wife would allow me to bring them in the house, I still think I got an OK deal.
I cleared out several other pairs of speakers to make room for these. I placed the "tweeters" towards the center of the room to minimize nasty bounces off the walls. Pictures later.
In case anyone is reading this to get repair advice just go here instead.
https://audiokarma.org/forums/index.php?threads/jbl-4430-and-4435-cheat-sheet.673961/
This is mostly about my personal experience.
I hooked them up to a Yamaha CX/MX5000 system. It was hard to tell if everything was working with the system they were on where I bought them. But I could tell all the drivers were working at least. Now I could tell that one of the tweeters was not putting out the high frequencies it should. At least not as nice as the other side. So I googled a while and found out that the crossover selector switches were a common problem. I pulled out one 15" driver to get to the crossover. Then put it back in because the crossover was on the other side. Brain fart. I sprayed deoxit into the selector switch and worked it a while. Then soaked the L-pads and pot while I was in there. I've never actually been that far into a speaker before. I have been inside a fire alarm panel (1945 vintage) and a radio transmitter but never a speaker. But getting inside the speaker is easier than removing the metal label on the face. Done that on L100 and 4312's. Hairdryer to melt the glue and a putty knife and LOTS of patience so you don't crease the metal label. Easily an hour each if you do it right. Never gain. But I digress. After I buttoned everything back up the high frequencies sounded much much better. Eventually I will do the other speaker but its ok for now.
Now I got serious about playing music. First, get everyone else out of the house. Done.
I played Foy Vance, From Muscle Shoals. Seems I love everything recorded at that studio. Especially the original Freebird. But I digress. The speakers seem to effortlessly handle everything I throw at them. I select a track and think "They will never get this right". Then they just nail it. Perfect every time. U2 Mothers of the Disappeared. Usually I can't even hear the first 30 seconds of the track. Now I could even tell there was bass and not just guitar. Wow.
But being who I am, I went onto parts connexion and put a full order of mills 12watt resistors, solen 600volt ppe caps and ClarityCap bypass caps. But some stuff was backordered so I waited on the order. Now I'm thinking I'm not going to mess with them. All the existing caps are film and probably aged well. So I'm not messing with them for now. But since I will never be using external crossovers I will pull out the selector switch. If you do pull out the switch, realize that the 20uf cap is not in the circuit anymore and will not need to be replaced. That can save a lot of money. I will also put in some modern binding posts. The speakers sound fine to me with the Lpads set to zero so I might remove them. but they are not scratchy anymore once I sprayed them and worked them a bid. To clarify for possible noobs: Lpads do not get removed but actually replaced with resistors to maintain balance in the network. The high frequency pot has a contact that bypasses it when it is at zero so really nothing will improve that.
Has anyone thought about a toggle switch to replace the rotary switch? Would it have to be a 5 pole switch? I have not thought it through.
One thing I don't like is using these for watching movies. I'm not sure what the problem is but my Polk RTIA9's are going to get flipped upside down and placed on top of the 4435's. There is no where else they will fit and still have proper positioning in the room. I'm flipping them so the high frequency drivers are closer to ear level. That might require another vacation for my wife. In their original location these speakers were hung upside down in a conference room apparently. There are internal steel reinforcements and ones set of eye rings still attached on the bottoms.
One thought: Is there a way to setup the 4435's to handle the LFE channel out of my Yamaha? Would that sort of be like an external crossover and/or bi-amping? It would be nice to keep my JBL E250P subs out of the room if they are not necessary. I gutted the amps on the subs and power them with one of the channels in the MX5000. I still have a couple channels left because 11.2 is too many speakers for sane people.
There is still some difference between the 2 speakers when switching my player to mono and switching balance quickly right to left. It might be that there is a sofa blocking some of the midrange driver at the bottom but I think it is more than that. Don't cringe about a sofa blocking a speaker, I had no other place to put them and the sofa could not leave. Pictures later.
The woofers have been refoamed so they are good to go. Another question (if anyone actually read this far), is there a difference between the two 15" drivers? Somewhere I read that one is weighted differently so it handles lower frequencies. But I cannot find that reference again. That might explain where some of my midrange is going (other than heating up the sofa).
The cabinets are in surprisingly good condition. A couples nicks on the back edge of the veneer and one "doobie" burn on the top that is lined up with some dark grain so it is even hard to see. Good grills.
So now off to listen to my entire music collection again again. Can't wait to get my CA/BA3000 back from the tech. Think I could drive this with a pair of Heathkit W5M's? 25 watts?
The rest of the bucket list: B&W 804 matrix (maybe 800d), Realistic Mach 1 (nostalga), Quad ESL 57, AR9. Most everything else is checked.
