I just acquired a pair of JBL L100 speakers with no grilles. I want to build a pair of grille frames and then order foam grille replacements that are available on Ebay. What I need is help on the dimensions of the frame itself. I intend to use a sheet of MDF and frame it with strips of walnut. Can anyone tell me dimensions on the original grilles of the following:
1. Width and thickness of the walnut frame edges
2. Thickness of the particle board face
I know the foam fits into a recessed area that would be the the difference of #1 and #2 above, but if you could also tell me what that recess is it would be nice to know.
Thanks in advance for all help!
