According to the technical sheet, the JBL L100T has a nominal impedance of 8 ohm, and a minimum of 6 ohm.
I'm currently running the JBL L100T with T3 crossovers hooked to a McIntosh MC402 8 ohm tap. There are also options for 4 ohm and 2 ohm taps.
Should I run it on which tap? Will I benefit from 4 ohm? Will I damage anything?
