salvador.gol
Member
Also the ported speakers have a little bit boomy bass below 60 hz. To correct this, fill big socks with parallel bunch of drinking straws and seal the ports behind speakers. Not tight, just be gentle.
Followed your suggestion - and wrote to Duaneage - but no reply. Are there any other people out there who you'd trust to do a good job on the L100T to L100T3 crossover job? 10/12/14 PM
Poor mans l100t to l100t3 crossover conversion and recap.Rule of thumb with inductors in series with the woofer is lower DCR will result in the amp having tighter control of the woofer motion.
I used this Erse 16ga 3.3mH I core because it has the lowest DCR*:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=266-914
Had to unwind a few turns to get it to 3.2mH. Bass is solid, but did not have much time on the stock setup as comparison, (so maybe better, maybe not, YMMV).
There is a pic of the inductor installed here:
http://www.audioheritage.org/vbulle...00T-quot-s-!!!&p=340694&viewfull=1#post340694
For the other inductors, I added enough turns of the same diameter wire to bring them up to the new values. This gets the DCR as close as possible to the original by only adding a few feet of wire to the original DCR...
* The 14ga 3.3 mH Jantzen Toroidal
(http://www.parts-express.com/pe/showdetl.cfm?partnumber=255-812)
_may_ have a lower DCR, but Toroidals are a lot harder to unwind. Either way you need an inductance meter to get it right:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-570
How much did it cost you? Do you by any chance still have Duane's contact info? I would like to do the same for my L100T'sDuane just did a crossover conversion to L100T3 for me. I’ve had these speakers since new and hope to make them last another 35 years. Here is the before and after.
