JBL L300/136a Help
Here is the 2216Nd1.. BTW The Nd stands for Neodymium, a rare earth element used in the magnets.. Bolt pattern matches, easy to install. These things were ridiculously light weight, when they came at the Post office I thought maybe the magnets were missing or something!
Although the 2216ND-1 sounds like it is a nice woofer, it will require a different crossover or DSP. The 2235H isn’t a 2216ND-1 but in an L300 it is only down 3dB at 26Hz, ... a completely different response from the L200 woofers or even the L300/L300A woofer.
I totally agree. I would never have bought these if not for triamping. (My L200's have 077 tweeters added). But I think that, particularly for these older speakers that active crossovers and multi amps brings its own rewards in SQ as well. Also complexity, but the improvements were worth it for me.
Mine were reconed way back in 10-1988. Before there were surround kits. New surrounds, twice since. Last in 2017, by Speaker Repair Pros. So far, they are still working well.
Another angle I am considering... are there any aftermarket kits that are worth a try for the recone? With the OEM becoming unobtainium is everyone just scrapping these if they go bad or has there been any "scientific" reviews of the usual aftermarket sources? I feel like it is such a waste to just have to leave it out to pasture....
I noticed that earlier in the week but had already decided to move on to replacing wholesale... now that I am rethinking, I will send them an email and see what they have. Thanks!
I've always replaced the woofers & subwoofers in my JBL, all at once. Expensive, but at least you aren't pulling speakers out of the cabs, every five years. Kinda like changing all tires on a car, at once. :)
Had someone ask, so I thought I would include a pic of the "refurb" finished product on one of them... would still like to get the woofer situation figured out, but for now they work, sound fine, and will let me play some vinyl.
I am located just outside of Chicago, ideally I wouldn't have to ship, but know that is probably a pipe dream... I will send a note to Speaker Repair Pro to see what they offer....
He is not cheap. He does quality work. I'm so glad he followed in the old Orange County Speaker's footstep. :thumbsup: All of my JBL Pro techs in Hollywood and North Hollywood have retired. :(
S/N 22670 is awful close to the change to 136H woofers, Edgewound might be surprised when he pulls the woofers if he's expecting 136As!
When I got my L300s, one of the original 136A was missing, so I sold the other one on ebay, and installed 2235H woofers into them. IMO, that is the way to go.
Agree, if one is not hung up on the original 136A’s, the 2231 alnico, or 2231H/2235H are the next closest to OEM. Many times though the Pro 22xx Series have gray frames, not black.
I have to agree.. I have never experienced bass this clear before! They are a great upgrade for these older L200/300 models, particularly as vintage replacement drivers and parts are drying up. The only way I know of to implement them is to biamp or triamp using also a DSP engine of some kind which is a drawback for many.. The 2216Nd1,s can really dig deep with DSP properly added. Mine go flat into the lower 20's hz and can do that at significant SPL. I have rattled things in the house, windows and such, with no sign of them giving up anything! Would love to hear 4367's or M2's but they are out of my $ league at this point.. This is the closest I can get!
While I agree with the experiences many have had with the 2216nd, where can you get them and at reasonable prices? Here’s one pair for $1500 obo now on eBay:
https://www.ebay.com/itm/JBL-2216ND...-/333906709693?_trksid=p2349624.m46890.l49292
What part of Mars are you located in? Bao at Speaker Repair Pros does excellent work, he’s done a bunch of drivers for me
Ken (edgewound) at Upland Loudspeaker also does great work and has been working on True Reproduction aquaplas coated recone kits as close to OEM JBL as possible. Check in with him about potential recone kits.
View attachment 2149353View attachment 2149355View attachment 2149356
Looks somewhat like a tight spot for L300’s, understood if that is the available room. They do like space though.
Is it just me or the foam surround looks abnormaly wide on that woofer?.
The 2235's are very narrow...
Yes. You are correct. In the late 90’s to early 2000’s, the only surrounds available were thicker wide roll, sorta generic polyurethane versions which mostly fit but were too thick and stiff. Somewhat thinner versions became available in mid 2000’s and with the advent of multiple suppliers, the correct narrow roll thin flexible and longer lasting polyether surrounds purpose fit to JBL cones and frames.
Below is the OP’s driver with original OEM thinner neoprene outer gasket. Note how the surround pretty much completely fills the spacing.
This is Mr. Boochie’s 2017 refoam done by Speaker Repair Pros with the correct narrow roll surround and gasket.
Just east of Pacoima, Mars. :D
Like I said, it's so good younger techs like Bao, are still around.
