Don't know where you got your foam from last time, but maybe it wasn't quite the poly-ether foam that is available today. That said, Rick Cobb's current foams are probably the latest types available. Would suggest though that you check Ebay for outer gaskets that go on top of the outer circumference of the foam after they have been glued to the cone and frame - to give it a much more OEM finished appearance, and to provide some level of protection of the outer roll's bend to the flat section.
4 sections is enough to do 1 woofer so you'll need to order two sets of 4 sections. There are other suppliers of similar if you search ebay for JBL gaskets and find the 15", but I'm not confident of the types from the Far East.
http://www.ebay.com/itm/JBL-Altec-N...hash=item483cab005d:m:mam53_zpaZ8bux18nBqcazQ
Should look like this:
Or possibly shutters or drop down blinds / cellular air blinds to partially block the direct sunlight but allow light to filter or diffuse in. The humidity and temperature though can also be a heavy degrading factor in this.
Best to keep a list of known good suppliers for the future. As for possible cone damage from sunlight, true it can happen, but I'd be listening for low frequency or mid-bass frequency distortion before committing to a recone - 2235 recone kits are hard to come by even in the US, so Jakarta could be difficult - may have to send to Australia or Japan for refurbishment unless you have a JBL service center in your country.
