So I have biamped my L7's and like how it's working. I'm sending full range input to the low end and using the internal crossover with terminal jumpers removed.
What I wanted to try is an active crossover for the low end. I know I can move the internal jumper on the crossover to bypass the LF components and use the active crossover instead. But I found active crossovers to be expensive. What I did find was an inline RCA active crossover emulator. There is one that does low pass at 150Hz that I want to try.
The problem is, this will not match up with the high end anymore. The bottom frequency for the high section will still cross at 180Hz, leaving a gap in frequency response. Is there any way to make changes to the high end crossover to lower it to 150Hz from 180Hz? Maybe use a calculator to find the right values for components? I wanted to do a recap anyway and don't mind experimenting, I can always put it back as long as nothing blows up.
