JBL N333 parts recommendation
intotubes
Well-Known Member
I have a JBL N333 crossover with the tweeter cap and resistor blown. The cap is 1uf/200V. The resistor is a standard sand resistor so no problem there. What kind of cap should I use? I assume its a film cap. Any recommendations on brand?
Other than a simple re-cap and resistor change,
What are your goals?
Exactly what components are you using?
If you have real L-300 cabinets,
Keep them as close to stock as possible for the Eventual resale value.
Changing a couple of caps and upgrading the wiring and binding posts,
Should not hurt resale value.
If you want the ultimate sound quality sure, you can change the woofers and possibly even replace the 1” Le85’s
with the 2” 375-376 driver’s and short horns
Use the charge coupled X-overs see the extensive thread posted on the Lancing forum.
You will never recover the additional $ spent on the upgrade's.!
But I can tell you the results will be very much better.
Choose your poison
Bobhorn
I just want to restore original function. The cabinets need some restoration so I am parting out. There is good resale value if one is willing to ship. I don't want to deal with that but I want to get some value out of them so parting out.
