Superampman
AK Member
I think my assumption the spiders are weak is incorrect. If they are deformed I would just use them as is. They may correct themselves from use. To speed things up, you may have to rock the house for a while though.
They had no surrounds prior to this. They had been sitting in a spare bedroom for 15 years and there was literally no foam left, so the spider had nothing to counter the tension.
Stored for a long period without a surround would explain a lot. If they were stored face up the sag would be more even. But if they were stored (in the cabinet) with the cabinet upright that would cause an uneven sag. Either way, hopefully they might self correct, but I'd think putting them face down for a period to allow gravity to do it's work might help more.They had no surrounds prior to this. They had been sitting in a spare bedroom for 15 years and there was literally no foam left, so the spider had nothing to counter the tension.
i noticed one of my jbl l36 woofers would make a scratching sound whenever the needle was put on the record by manual means. i refoamed them a few years ago. took the woofer out and the spider was sagging i turned the woofer around one revolution not backwards.intsalled it back in the cabinet. result 90% better.
the surrounds were gone when i bought them at a garage sale. $20.00 and complete with warranty cards. best $20.00 i have spent.
I've never doubted "workarounds" as people are constantly supplying them. I'm only saying here that while these are all fine and good, they are not solutions. Some day, eventually, spiders that are sagging will need to be replaced for "optimum" performance.
I won't discourage people from trying the recommendations here, but do keep in mind workarounds have their limitations.
As an example people have been told that if they removed the belt from the pulley or entirely from their TT they can extend the live of the belt. To a certain degree this is true, however, rubber will continue to rot and will eventually need to be replaced. How much longer it will last I'm skeptical about, since rubber does deteriorate.
Didnt pay attention, to be honest. It was after that ot was brought to my attention
I'm guessing he asked because the 128H was built with at least two different size (diameter) cones, and therefore there was more than one surround size made for it. Get the wrong one and it could result in alignment issues though I am not sure that would cause any spider sag.
I've never had problems with any of that myself but I use an authorized JBL service center for refoams on these woofers and they definitely know to check for which surround to use.
