JE Labs Open Baffles for 12 inchers
yup - that is one I was looking at . . the other is the JE Labs 45 / 2A3 . . .
Markus, let me know if you want to go this route - I'll send you a spreadsheet of the parts I sourced for mine, and their associated costs.
thanks redboy - I've been checking into your thread occasionally. . . I have lots of the power supply parts (power transformers, chokes), and tubes (rectifiers, 45's, one set of valve art 2a3's . . .) , my main cash outlay would be output iron, and all the little bits - caps, resistors, etc . .
Markus, did you change the size of the baffle from the original plans?
I noticed that the cutout is for an 8" driver.
Uh, nevermind. Read the whole post and now understand.
I kept the overall dimensions exactly the same as in the plan, I just made the opening for a 12 . . . basically just made the center of the circle at the same point ( 13 inches up , dead center ). some of the links off the JE Labs OB webpage have guys using even 15 inch drivers - I plan on enlarging my openings to accomodate 15 inch drivers too - I wasn't happy with my circular cut - a little off . . I need to redo with a circle jig :yes:
HA ! just noticed your last comment . . . too bad - I already typed all this :D
