amrzs
I am currently using a Jelco 250st tonearm with a Denon dl 301mkii cartridge through a DIY step up transformer, and it sounds incredible. My question is would this same cartridge be a good match for a Jelco 750d tonearm? It seems like the 750d is an upgrade in every respect from the 250st and I was thinking of using it for an upcoming lenco ptp project. I'm a bit confused though because Jelco lists the effective mass of the 250st at 18.04g (originally I thought that this figure was lower) and the 750d at 19.23g, which is very close, and places both tonearms in the medium mass range. And while I have always had good luck with medium and higher compliance cartridges with the 250st (other cartridges include shure v15, Shure m97xe, and Denon dl 110) it seems like most people prefer lower compliance cartridges with the 750d such as the Denon dl103. I realize that Denon measures their 103 at 100hz so their compliance figures can be misleading, still there is no mistaking that the dl 103 is a low compliance cartridge that does best on high mass arms and the dl 301 mkii is of medium compliance and does best with medium mass arms. I have heard the dl 103 in the past and I much prefer the dl301mkii, but I'm unsure if my step up transformer is what's giving me the wow factor with the 301 mkii, or if the dl 103 I heard was even properly set up, or some other weak link is to blame, as I've heard great things about this cartridge. Luckily my SUT is compatible with both cartridges, so if I decided to go with a Jelco 750d I could always try both and see what I like. It just seems odd to me that my 250st mates so well with higher compliance, when it's not too far off in mass from the 750d with which lower compliance seems to be preferred. I realize the 750d has oil dampening which could have a lot to do with it. If anyone has experience with the 750d I would greatly appreciate some input. Also my SUT was built with loading impendance and gain ratio with Denon cartridges in mind, so while other cartridges are an option the only low compliance one that would be ideal for my set up that I know of off the top of my head is the dl 103. So if I end up not liking the 103 I guess I would just hate to be stuck with an arm that only mates well with low compliance and have to build another SUT for a different cartridge. While I am used to, and very happy with Jelco tonearms, I am not exactly married to them so I'd also be open to some other suggestions for to medium mass tonearms that would be an upgrade from the 250st, but in a similar price range to the 750d. Anyway, sorry for sort of rambling there, but any input would be appreciated.
