2325Veepster
Hi All,
I just received my JICO neoSAS-S for a Shure N91ed and I want to double check some things before I try it out. It’s going on my AR XB with a stock headshell. The price for this one was right plus a good m912ed cart body, so I went with it despite knowing that people seem to love boron and that this is a pretty high compliance unit for the AR in some folks minds.
I run a M93E with the original hi track stylus now. My understanding is that the function of the 912ED and 93E are identical (along with other numbers) except for the style of the body mounts and shrowds/clips.
First question, is there any reason to use the body of either variant I have over the other? I don’t know if the metal clip of the 93 is less than some how or vice versa.
Second question, if there’s no difference other than appearance, how do I use a multimeter or something to check which cart body is in the best shape and most worthy of this special stylus? I’ll accept links or references to trustworthy guides too. I have two M93Es, a strange SPS Omni body, and now this M912ED, I think they are all this same family.
Last question is more generally if there’s anyone that’s run this in an AR XA or XB that has some tips for installation and set up. I didn’t get the instruction manual with the stylus, just the box, so my next step is to look one up for the recommended settings. I’d also appreciate if someone with experience with this or similar application wouldn’t mind sharing wisdom.
Thanks!
Thanks!
