That's not an answer to my question.
Jolida specs the DAC at 0.01% THD. Noise isn't even on the spec list. Is this enough for you?
I made a rather naive assumption it would seem - that as you objected to the use of a valve as DAC OPS on grounds of distortion and noise, that you'd know how much of those undesirable elements a valve introduces. But clearly, my assumption was mistaken - lesson learned.
Yes, but we are discussing (at least I thought we were) how much degradation a tube stage brings to the party. In 'Classic mode' that DAC's limited by its DAC chip on noise, not its tube stage.
tube-it, thank you for your reply and information. I am glad to know the Jolida uses tubes RATHER than transistors and then tubes in the output section. I agree with your comments about the sound. I have two of these and enjoy the sound. So back to my original question, do you have a recommendation as to tubes which sound best with these. I now have lightly used RCA 12AX7 and lightly used RCA black top 12AX7's. I can barely, barely tell the difference if I try. I am using a Classe 47.5 pre and CJ Classic 60 SE power with Vienna Acoustics Beethoven speakers, good wire. Thank you again!
