Can you believe, before clipping, 892.26 watts per channel @ 4 ohm/1 khz.:yes: Made a pot of coffee on the DL as well..After getting all the minor issues squared away.I hooked this "bad boy" up to a 4 ohm DL.......Can you believe, before clipping, 892.26 watts per channel @ 4 ohm/1 khz.:yes: Made a pot of coffee on the DL as well..
Good to the last drop..
yowzas! to run with both channels at 4-ohm clipping, i'd be looking at a 30A circuit (assuming 50% efficiency)! fortunately, i don't think there are many speakers that can handle 900Wpc continuously.
Actually the load didn't really get that hot.Wasn't sustained at max power that long..Maybe 45 seconds.Just long enough to adjust the voltage cursor on the o'scope for peak voltage. That and major overkill on the dummy load..Made a pot of coffee on the DL as well
