I mentioned more than one cartridge (AT450 and AT132EP). They are both better than the AT92ECD you have. It's a good cartridge, but not one of the best P-Mount cartridges available. Perhaps it was one of the best in current production at the time you purchased it. The "best" P-Mount cartridges available are no longer in production
Here's a complete word for word copy of a post I made recently about some of the "best buys" currently available in P-Mount cartridges. Note, these have all been discontinued, but continue to be available as NOS on eBay.
Although the AT450 from the eBay seller is the highest quality P-Mount cartridge/stylus currently available at an affordable price, there are other bargains to be had in the same AT P-Mount family. Keep in mind that same style of AT cartridge has been around since the advent of the P-Mount standard and sold under probably > 100 different model numbers (if you include all AT variations, plus all the ones they OEMed for various turntable manufacturers like Sanyo, Sharp and Sony - and that's just the ones that start with "S").
I only have one P-Mount table, a tiny little Technics SL-5, that is a surprisingly good performer with a nice cartridge/stylus on it. It came with a very excellent AT132EP cartridge on it with the original stylus in excellent condition. I have been running this table in my office system where it gets little use, but am considering running it as the secondary table in my home system for playing thrift store vinyl. Plus, sometimes it's fun to just close the lid, hit play and let the turntable do the rest. The replacement stylus for the AT132EP has gotten rather expensive. So, I have stocked up on a lifetime supply of "lesser" Audio Technica P-Mount cartridges and genuine Audio Technica replacement styli:
Top left is the universally loved AT450. Top right is an AT320, which comes with the 03 x 0.7 mil "Special Elliptical" stylus (ATN3472SE = 213-SE). Center are two AT3472L cartridges with 0.6 mil conical styli (ATN3472 = 213-D6C) and at the bottom is an ATN3472SE "Special Elliptical" replacement stylus. I have a third AT3472L currently on the SL-5 turntable and another AT3472 (213-D6C) on the way that I picked up for $10.44 shipped this morning. Other than the ATN3472SE replacement stylus, everything in the photo came from that same eBay seller, and in my opinion all were screaming good deals for anyone with a P-Mount table.
Even the "lowly" 213-D6C conical sounds very nice on my SL-5 turntable. Each step up, from the conical to the special elliptical to the nude elliptical buys you a little more refinement, detail and separation, while retaining the same basic sonic signature. I always prefer to have two tables at my disposal: one with a low mass tonearm (Harman Kardon T60) for my vintage high compliance cartridges, and in the past, I've always had a Japanese direct drive table with a medium mass arm (most recently an MCS 6700) for playing my less than pristine vinyl. I accumulated a number of headshells so I could easily swap cartridges on that table as my mood and the quality of the vinyl dictated. Well, guess what, it's even easier (by a lot) to swap cartridges on a P-Mount table. Yes, the options are more limited, but for a back up table, with a combination of conical, special elliptical and nude elliptical cartridges and stylii, I'm good.
By all means, encourage your friend to get another AT450 while they are still available, but if he's in this for the long haul and plays a lot of records he may want to also pick up a couple cheap conicals (AT3472L) and a special elliptical or two (AT320) while he's at it.
Here's the manufacturer's specs on each, so you can see, in numbers, what you get as you move up the food chain:
AT3472L:
Stylus Profile = 0.6 mil conical
Freq. Response (Hz) = 20 - 20,000
Output at 1kHZ, 5cm/sec = 5mV
Channel Separation at 1kHz = 26 dB
Channel Separation at 10kHz = 16 dB
Channel Balance = 1.25 dB
Vertical Tracking Force = 1.0 - 1.5g
AT320:
Stylus Profile = 0.3 x 0.7 mil bonded elliptical
Freq. Response (Hz) = 15 - 27,000
Channel Separation at 1kHz = 29 dB
Channel Separation at 10kHz = 18 dB
AT450:
Stylus Profile = 0.3 x 0.7 mil nude elliptical
Freq. Response (Hz) = 10 - 27,000
Channel Separation at 10kHz = 20 dB
Channel Balance = 1.0 dB
And just for completeness...
AT132EP:
Stylus Profile = 0.2 x 0.7 mil nude elliptical
Freq. Response (Hz) = 10 - 30,000
Channel Separation at 1kHz = 30 dB
Channel Balance = 0.75 dB
Vertical Tracking Force = 0.8 - 1.8g
For comparison, here's the specs on your AT92ECD:
AT92ECD:
Output at 1kHZ, 5cm/sec = 3.5mV
Assuming you still have the original stylus, it's basically a lower output version of the AT320 listed above. Again, not a bad cartridge, not bad at all, but the the AT450 and AT132EP are both better, both in specs and to my ears (compared to the AT320). The AT132EP is in short supply,hard to find and relatively expensive compared to the others. The AT450 is almost as good and available on eBay from seller wolfsbigbadgarage at a VERY reasonable price - for now.
Your AT92ECD is a very decent, inexpensive cartridge I highly recommend you use it and enjoy it, but if you think you are going P-Mount for the long haul, definitely get one of the AT450 cartridges while you can. You won't regret it. Not for one second.
