last one I had I bought...and then sold for $50
Its got the devil inside it....
Just found this TU-666 in the attic.
Same here; the roundie coolness wore off after the first daylast one I had I bought...and then sold for $50
Your tuner does not have much to clean using the Deoxit. Maybe the selector and those two noise cancel and muting buttons. Volume, balance, tone pots usually give you trouble when oxidation is present, but tuners usually don't have those pots.Thank you all. I cleaned up the exterior, and now I’m wondering about the cleaning inside the tuner. I’ve been reading about non-residue contact cleaner, Deoxit, and do’s and dont’s ad nauseam, but haven’t found too much info on cleaning the TU-666 specifically.
Is there any “safe” cleaning I could do without risking any damage? Benefits of doing so? I’ve used some compressed air to remove dust, but there are still some dirty parts. And I know not to touch those fins.
If you want to stay original, here's a ebay listing for the power switch. (no affiliation) Looks like you may be able to clean your switch through the opened side, too.Okay, less moving parts is good. Now about the power button...it is a push button with a spring. It works, but moves a bit loosely with and without the faceplate on. It seems to set in firmly only when the plastic cap touches a particular spot on the metal part of the button right behind the faceplate. However, it doesn’t stay in that position. Is the plastic cap and spring supposed to adhere to something? The button is also a bit slugging when moving outward to “off” position.
thanks again
https://www.ebay.com/itm/Sansui-AU555A-Amplifier-Power-switch-Alps-/183735514652
Also, here's a place where you can download a copy of service manual if you need it.
https://www.vintageshifi.com/GAMME-SANSUI-2.php
I'm not sure, but it could be the mechanical issue or a contact issue. You would really have to open it up but I don't know if that's possible with that switch.View attachment 1718742
This is a picture from that link; I haven’t taken apart my tuner. That open part at the rear is where it slows when moving outward to the “off” position. The metal parts slide past each other, but there’s no electrical contact in that particular spot. Do I still need to use DeOxit or would another cleaner or lubricant work as well?
