Just got my first McIntosh! A MAC 4200 Receiver.
creator12
Hello!
Over the course of the last couple of years I have been split between two systems that were both primarily made up of Yamaha components.
My first system at home contained a Yamaha R-100 receiver, K-2000 cassette deck, Genesis 1+ speakers, ADC Sound Shaper One Ten MK.II, and a Dual CS-5000 turntable with an Ortofon 2M Blue cartridge.
My second system at my apartment near school was made up of a Yamaha R-50 receiver, NS-6 speakers, and a P-300 turntable with a Grado GF-3 cartridge. Eventually the P-300 turntable at school was replaced with a Technics SL-1200 MK.II which then had a Ortofon 2M Blue cartridge added on.
When I eventually made it back home for quarantining and online classes, I decided that I wanted to keep both my turntables (as I was graduating and no longer had any need for two seperate systems), but I needed a new piece of equipment to allow for the usage of both in my singular system. I initially tried to use a phono switch box which would allow for two turntables through a single phono port, but I found that the amount of electrical noise in the background was overwhelming and instead went for replacing my receiver.
I decided to look for a piece of equipment that was built throughout the 80s (to match the rest of my equipment) that preferably would maintain most of the functionality of my Yamaha R-100, but with the ability to build on for future system upgrades. After about a month of research, I came across the MAC 4100, 4200, and 4300V. I immediately focused on the 4100 and 4200 as both supported dual phono ports, however the industrial design of the 4200 won me over.
I then went through eBay and found a MAC 4200 with a starting bid of $800 that was listed as being in "Tested" condition. It also appeared to be in pretty good shape physically. Thanks to Bidnapper I was able to get it for a little around $1,175.00 before shipping and taxes, which brought the price to $1,280.99.
Over the course of waiting for a couple days, I researched quite a bit more into the history of the MAC 4200. Through Audiokarma I learned that it had an extremely low production run and a history of potential battery problems through the AM/FM tuner which came down to the usage of three rechargeable AA NiCad batteries. Beyond this I was happy to learn that the 4200 had been built in McIntosh's factory in NY and generally had a good reception online as a quality receiver.
Once I received my receiver at the beginning of the week and started my testing, I discovered that my unit had succumbed to the same problem with the rechargeable batteries. Again, thanks to Audiokarma, I was able to read into posts from 2009 and 2019 that dealt with the replacement process for the batteries.
I am no expert in electronics, so I was incredibly happy to see that it was just a matter of pulling out the old batteries and removing dried battery acid with isopropyl alcohol in the battery slot. I used Living Accents Ni-Cad AA 1.2 volt Solar Rechargeable Batteries from Ace Hardware (https://www.acehardware.com/departm...ctrical/batteries/specialty-batteries/3909728) as a replacement for the original Sanyo batteries.
Over the last 24 hours I have had no problems with the new batteries and now my receiver is completely functional. I've only used it for a couple days but already I prefer this to the R-100. The only two functions I lost from the R-100 in switching over was the usage of a remote control and the ability to save 10 stations instead of 6 stations. In my opinion, it is a small price to pay now that I could connect an additional turntable and set of speakers (2 sets to 3 sets).
I have included pictures of the battery slot if anybody needs them for future work on their MAC 4200. I will post my full setup soon to show how it changed from the R-100 to the MAC 4200.
-J
4200s are so hard to find, & I always wondered, is there only one Tape monitor set? BTW, White vinegar on the Q-tips is significantly more effective on the battery crust, as it is highly basic. Then you can clean it with alcohol.
On the 4200 there are two tape monitor sets! Thank you for the white vinegar suggestion. If I open it again any time soon I'll try to clean out the rest of the gunk with that!
