rab32chevell
Member
OK! Since joing Audio Karma recenntly, I'v heard all the buzz about the 7t. It's strange, in all my years in Hi-Fi, I never heard a single person ever talk about the 7t. Personally, I'v owned about a dozen 7Cs, so I am familiar with much of the 7t. All but the sound of the transistor version. After thinking about it, it seemed to me that since Sid Smith designed it (I think), it just has to have tremendous potential since Sid was a master transformer designer which is why the power amps He designed are still fantistic today. The guy I bought it from off E-bay yesterday said it has a problem. He says when you turn the balance control all the way to the left, both channels turn off. Any ideas of what can be causing that? I know, from reading all the threads about the 7t, that replacing the caps may be necessay. It has a 12400 serial number so it may be one of the earlier ones. Jstang said he heard the earlier ones may sound different than the later ones. Has anyone looked into that aspect further? No matter what, the Marantz 7t just has to be the best buy in the world today in a pre-amp considering that for $500 today, all you get is a little box with a cheapo phono pre-amp in it. One of the reasons I wanted the 7t is because it has TWO main outputs and I run two Marantz 500s. One on each channel. Having an output for each channel/amp will make things much better. Any and all information you can share about the 7t will be much appreciated. Thanks for listening.
