Just recapped a SA-6500ii, well worth the work
rkgren1
I found an SA-6500ii in a thrift store a few weeks back.
http://audiokarma.org/forums/index....oodwill-sa-finds.6803/page-1245#post-11547831
The cover is a bit rusty, there is still some mildew in the corners, and it has a few bumps and bruises, but I really liked the sound of it, and thought I would keep it for a while, so I ordered caps and transistors for it, relying on MarktheFixer's recommendations. I left the filter caps as-is. I may re-stuff the cans later, but power supply voltages are solid. I now have about $30 in it.
I went through the thing last night and this morning, doing the power supply, and then working my way through phono, pre-amp, tone controls, and power amp sections. It took perhaps 10 hrs. of time total, but I really took my time to minimize mistakes (only 4 due to typos in a table tracking the work). I probably did 2 hrs. worth of prep work as well, measuring and matching transistors, printing the schematic and foil side drawings, reading, etc. I did a lot of DBT testing to make sure things were staying on track.
This was the easiest thing that I have worked on so far. Not one component was difficult to get to.
I still need to replace the little power lamp bulb, and I should paint the cover, but it is functionally done. I have been using it for about 8 hours so far.
This thing is really sweet-sounding now. The low frequencies were essentially unchanged (still strong), but it picked up some more definition in the high frequencies. I have a new favorite.
It is presently in my living room system, driving a set of Realistic Optimus 5Bs.
They are a nice complement to this little amp.
Why not also change the main filters? They take a hammering with ripple. There is some that think they don't influence sound quality. I'm undecided on that
but have recognized that most of the watts we hear typically comes from the main caps/unregulated supply to the output transistors... Tempted to go with
Nichicon KW 10000uf/50V, but that's another debate...
I can do the big filter caps later. I will not be running the thing hard.
I have recapped several receivers in the past, and I have never noticed a change in sound quality from changing them out.
I will likely stick close to the factory capacitance values if I replace them.
This little amp keeps sounding better to me. It is nice and warm, but it also has a real sparkle to the sound, if that makes any sense.
It is really gets on well with the Optimus 5Bs.
