Qwadrafoniq
Hello everyone,
New guy here that's been reading the forums for a while and now needs some advice. This JVC 4VN-880 has been in the family since new (1973) and has been used on a daily basis. I currently have it set up with a pair of Wharfdale Lintons and an SMSL SU-9n DAC and it sounds glorious....well, it did until last month.
It's used at the moment in stereo mode (rear switch set to 2 speaker setup) and it's alwasy been whisper quiet with zero hiss on either channel. Suddenly turning on one day recently channel 3 now has a faint but annoying hiss that's getting slightly worse over time. The hiss is like the background static and is constant. No crackling or other noises. It is not volume dependant or input dependant, it is constant. It doesn't matter what input you're using, what source your'reusing or what speakers you're using, the sound is constant. The cables are good grade and I've swapped them with no change.
I called Robert at Excel Audio Services (SM6) who has vast experience with most things Hi-Fi related and whilst he was familiar with this amp, he did say that he'd never come across a hiss like this before that he will take a look at it but recommended I ask about first to see if there are any other 4VN-880 owners that have had this issue or if there are any JVC specialists on this forum who might have an opinion?
Does anyone have any ideas whagt the source of this hiss could be? Channels 1,2 & 4 are perfectly quiet, it's just 3 that has this issue. I will say that the amp is a bit of a family heirloom and I absolutely love its sound with these Lintons. I'm happy to try and fix any issue.
Many thanks for any advice offered.
Rod
Rod
