pioneer07
Member
I am wondering how screwed I am here. I snagged this AX-R97 for $30 on marketplace. It needs some work. It has that nice display on the front but the fuse lamps were burnt out. I've replaced fuse lamps in 1 other JVC receiver and I was aware some diodes likely got fried when the lamps burnt out. For the heck of it, I did just try replacing ONLY the lamps, but they didn't turn on. I dug a little deeper and there are at least 5 diodes that got fried (D812, D815, D831, D832, D833). There was also a resistor (R843) that partially crumbled when I touched it.
What I did with the other JVC when I replaced the fuse lamps is I just removed the diodes and ran the lamps in series, and that worked. So that was my plan for this one. Here is the thread about that other JVC.
R843 is the main resistor right in front of these fuse lamps that cumbled. The manual says it is "10 UNF Carbon 1/4 W". I was like, oh, I have a 10 ohm resistor that's rated well over 1/4 watt. I removed all the burnt out diodes. I also lifted the center connection between the lamps and left that open to make it a series circuit. And of course replaced the R843. The lamps briefly came on. Then I got a little smoke and quickly shut it off.
I'm very confused what this R843 resistor is supposed to be. The bad resistor measured about 280 ohms. I figured that number was totally unreliable since it was so damaged. The colors on that old resistor are 5 band, and it looks like white-red-black-black-silver (920 ohms??? or are they using an older version of the colors?).
Prior to this, I was getting 37 volts at the right side of that R843 resistor (which looks correct per the schematic). Afterwards, I'm getting -0.4V. That means transistor Q802 is also likely cooked. Worse, when I tested out the unit again, there is distortion that was not there before. The concern now is a current or voltage spilled into another area of the circuit and damaged something else. Is there hope for this unit? I'm not going to do much more work on it if you tell me that I fried some hard-to-find IC chip or something.
Here's a link to the service manual and a screenshot of the part of the schematic with the fuse lamps, and what it says for R843.
